Edelbrock Performer RPM LT1 Air Gap Manifold?
Pitäis tuollasesta olla mainos syyskuun GM High Tech Performancessa (sivulla 11). Onko siinä hintatiedot samassa?
Juttua täällä ja myös täällä.
Asennusohjeetkin löytyy, mutta itse tuotetta en oo löytäny...?
Oliskohan tuollasesta oikeestikin hyötyä?
hetkonen.. luulin aluksi että kyseessä oli se yksitasoinen malli.
Voihan toi olla parempi jos siinä on malmia tehdä runnerit korkeammiksi ja nätimmät venturit plenumiin.. ja mahdollisesti hieman pidemmät runnerit.
05-02-2006, 09:14 AM
LT4 Intake info
Talked to my contact at Edelbrock today. He specificaly said the two LT_ intakes are a go.
They are still in development.
Won't be available for " 2 to 4 months, maybe sooner ".
He told me to check back with him in 2-3 weeks for an update, since there are four development stages and the project could progress quickly if casting porosity quality checks out ok.
I also asked him about what happened to the old intake that was supposed to come out in 1998, he said that at that time it was very difficult to cast that intake so the project was dropped, BUT, now advances in casting technology will make it more feasible today.
He assured me this manifold is a go.
I will post up an update in 2-3 weeks.
__________________
Joe Fernandez; 1995 formula 6m, BMR stb,sfc,lca,phr,moroso cai,160therm,tb bypass,1le elbow
08-25-2006, 10:46 AM
TUORETTA JATKOA : :(
Re: LT4 Intake info
Sorry for the late reply, but I spoke with my friend at Edelbrock and got a striaght answer:..................................
Production of the air gap LT1 and LT4 manifolds wont be until the year 2007 , the reason being that Edelbrock is working on other " higher priority projects ", by this I believe to be { potential cash producing projects other than LT1 or LT4 manifolds }.
There it is kids, short and sweet, I know there will be whinning and bitching but basic business economics dictate reasearch and development.
__________________
KOKO TOPICCI: http://web.camaross.com/forums/showthread.php?t=447898
  • 2 weeks later...
Pitäs tulla markkinoille tän kuun loppupuolella.
  • 1 month later...
Mistäsä tämmönen tieto???
ainakin tieto ko sarjoista löytyy jo edelin sivuilta: :P
http://www.edelbrock.com/automotive_new/mc/manifolds/chevy_sb_fuel-inject.shtml
For Chevrolet LT1 and LT4 V8 (1992-1997)
PERFORMER RPM AIR-GAP™ (1500-6500 rpm)
Utilizing the proven short runner tunnel-ram style,
both of these manifolds provide the next step up in performance for LT1 and LT4 owners.
These are both direct stock replacements for OEM equipment with all required emissions features.
Our patented Air-Gap™ design delivers a cooler and denser air stream for maximum power output.
These intake manifolds are designed to work with either our #3809-52mm or #3810-58mm throttle bodies.
They also accept early and late OEM LT1 throttle bodies and fuel rails.
#7107 and 7109 are designed to match #61909 and #61919 LT1 cylinder heads,
but will also work with OEM LT1 and LT4 heads with minor head port matching.
Performer RPM Air-Gap for LT1 #7107
Performer RPM Air-Gap for LT4 #7109
Installation Notes: Recommended intake gasket: LT1: GM #12524653, LT4: GM #12367777, LT1 Port Exit Dimensions: A-2.06", B-1.15", LT4 Port Exit Dimensions: A-2.12" x 1.20"
08-21-2006, 01:17 AM
The Engineer
Registered User
Premium Member
Quote:
Originally Posted by 96ZCamaro
Yea I also saw it in GMHTP and it said now available. Idk why they would list it as available and not sell it to people. But I guess it could be just like the msd opti too where it took forever to come out.
After I saw the add in GMHTP about two weeks ago, I called Edelbrock tech department. They said, "it isn't available and could not say when it would be be." Additionally, the person I spoke to seemed somewhat indifferent about my interest from their add. I guess us LT people are such a small market we really don't count.
http://web.camaross.com/forums/showthread.php?t=467445&highlight=Edelbrock+Manifold
  • 1 month later...
  • 2 weeks later...
Guest DARK FIREBIRD
Eiköhän ebayssakin lt4 imusarjojen hinnat laske pian.
Pyörittelin ks. imaria  käsissäni ja jos joku haluu maksaa heikosta valutyöstä joka painoi kuin synti niin siitä vaan. Oli aika surkea esitys minun mielestäni. Toisaalta jos haluaa tommosen niin sitten ja onhan toi hyvä aihio modifikaatioihin. Vakio on monta kertaa paremman oloinen. Lt4 ja Lt1 mallit tehdään samasta aihiosta jonka huomasin messuilla Orlandossa kun oli Edelin osastolla molemmat esillä ja paljon muutakin hauskaa. ;D Itse Vic oli esittelemässä tuotteitaan.
  • 2 weeks later...
Mulla  on Edelin kannet ja TB52 just tohon imariin.Oisko toska jotain hyötyä... m/
RP:ssä on tommonen hyllyssä jos joku haluaa käydä ihmettelemässä. ;D Joten saatavuus tuskin enään on ongelma.
Tuollanen tosiaan siellä hyllyssä lymys. Ihan omin silmin sitä tutkailin.
Halvalla lähtee, nopein hakee sen sieltä pois.
Senior, jos tuolla löytys ne muutama puuttuvaa konia. Olis komee yhessä niitten kansies kanssa  ;)
  • 11 months later...
Onko tästä jotain juttua jossain, että onko merkittävää hyötyä ostaa...?
Jenkkiporttaaja Lloydin sanomana:
"The edelbrock LT4 is almost as good as a ported LT4 intake from me but a ported Edelbrock intake is even better"
  • 8 months later...
Uusimmassa GM High Tech Performancessa oli dynotesti tästä imarista. Aika heikot tulokset:
Vakio LT1 imari + vakioläppis 350.4hp@5600rpm 386.7lb-ft@4100rpm
Edelin LT1 imari + vakioläppis 346.8hp@5600 387.7lb-ft@4100rpm. Rikkaalle meni, mutta keskiarvotehot ja -vääntö kasvoivat hitusen
Edelin LT1 imari + 52mm läppis 350.3hp@5500rpm 391.3lb-ft@4000rpm ja taas kasvoi hieman keskiarvot.
Melko kalliilta hevosilta kuulostaa. Seuraavassa numerossa testaavat vielä Edelbrockin kansien kanssa.
  • 1 month later...
Jatko tulokset tassa
Stock heads, edelbrock intake & throttle body            hp 350.3@5500rpm  tq 391@4000rpm
Edelbrock heads/cam, stock intake & Throttle body      hp 389.5@5500rpm  tq 389.6@4600rpm
Edelbrock heads/cam, intake & throttle body              hp 393.3@5700rpm  tq 393.8@3900rpm
Cam edel 218 degrees of duration, .525-inch lift and a 112LSA
Varmaan pikku avarrus vakio-LT1:een antaa paremman hyödyn...
Mielenkiinnolla odotan "mun" imusarjaa, pääsee vertaamaan näihin tuloksiin... ;)
Jaahans,  onko nuo mitattu koneesta, vai takapyöriltä ?
Jos verrataan mun camaron kombinaatioon,
Le1 Heads, Hot Scam kit,
Intake 218 deg, exhaust 228 deg,  LSA 112 , ja nostoo 0.60,
niin kait mun camarosta löytty hieman enemmän kuin tuo 389,5 HP ?????
NOh eij oo penkitetty, mutt, pers tuntumalla, "kyllä lähtee"
Tosin kun mä ajan on kyllä aina vähintään kaks kyydissä,  massaa 135 kiloo ;D
siinä tasotusta monelle liikaa *clap*
eipä tullu viime kesänä ajeltuu kuin ca 1kk,  kun oli pakko pitää käyttis liikenteessä,
ja kyllä vanhaan foortiimme me mahdutaan niin paljon paremmin koko poppooo.
kaks autoo maksimi mitä pers kestää pitää liikenteessä yhtä aikaa siis.
